Glad you've sorted it!
Also stops me making the same mistake with the second H4 & my H5 B1...
OJ's H5 A3 Troubleshooting
- olivier.jan
Re: OJ's H5 A3 Troubleshooting
Glad it helped someone
Now, looking at the pinout, one should be able to use the original IC by swapping pin 4 and pin 5 and bringing power to pin 6. But not really sure it’s worth it unless one is in desperate needs to get it working without waiting for parts...
Retro stuff
- olivier.jan
Forget what I said about swapping 4 and 5.
Retro stuff
- olivier.jan
Hi, This morning I took my H5 out of storage and discovered it didn't boot.
Plugging the Diag cart I manage to get a display which is normal at first then stays stuck on "Testing MFP, etc...." with artefacts on the screen
Here is a short video :
(BTW, I didn't find how to attach videos directly).
I suspect the MFP as I've always had issues with the MFP on the H5 and I'll start the usual troubleshooting but if someone has a clue or seen this before it can save me a lot of continuity testing...
Retro stuff
- olivier.jan
I checked continuity on all MFP pins but didn't find any issue.
I tried in Mono mode (changing JP4) and instead of being stuck on Testing MFP I immediately get E7 Spurious Interupts.
Booting without diag cart,in Mono gives me many bombs and in colour mode I have a black screen with frequency changing between 50 and 70 hz continuously
Retro stuff
@olivier.jan try serial and see if you get any further info. Does sound like a poor connection on a chip
You can't, not really. Inlining YouTube or Vimeo as you've done is the right thing to do.
I'd second this suggestion, diag cart and serial out, it may show that the machine is running and has a video fault, or may highlight something else.
