OSI 600D Superboard Build
Re: OSI 600D Superboard Build
OK, so C6 replaced with the correct value but no difference.
I also pulled U62 in case that was bad, It wasn't, and also tried with one leg of C6 lifted, but still no output on Pin 6, so replacement CA3130's are ordered.
Provided I then get output from that I can then start to chase down where the output gets to and if R57 works to adjust the input as expected.
So I think my CA3130 was a fake, here are the new ones on the left, old one on the right:
All 3 of the new ones work just fine, and I get a nice signal where I should at pin 6 of and over at pin 5 of U69:
The blue trace is at the tape in currently coming from the aux out whilst I do a save, and the yellow trace is pin 5 of U69. The pulse width at U69 is within the range of 500uS to 630uS according to the service manual after adjusting R57.
I am able to save however I don't know if saving is working 100% as I could have cassette and tape player issues, so whilst I get what sounds good when I save, when I try to load it back in it's garbled. Nearly there though and I can test with another cassette deck.
I wonder what chip the original was. Maybe a 555 timer.
stephen_usher wrote: Thu Apr 25, 2024 3:06 pm I wonder what chip the original was. Maybe a 555 timer.
Wouldn't surprise me.
OK, so I have made some progress thanks to help over at osiweb.org.
I was given a small basic routine as follows:
10 SAVE
20 POKE 61440, 21
30 PRINT "U";
40 POKE 14,0
50 GOTO 30.
What this odd little routine does is similar to the test from the service manual, but it causes a 150Hz signal to be sent from the 6850.
Then by jumpering from pin 9 of the expansion connector to pin 10, this 'save' signal then gets routed straight into the cassette in port, and it can be followed all the way through back to the 6850.
What I ended up having to do was swap U62, U63 and U69 for various different makes, and I finally found a combination that gave me this:
The yellow trace is the output from the 6850 and the blue trace is the input into the 6850. The shift is normal according to the folks over at osiweb.
I'm now getting partial loads and things are starting to almost work and I'm fairly confident that the save part is good as I am almost able to load a complete program from tape that I saved previously.
All of the ICs I removed and swapped about seem to be working just fine according to the TL866, but clearly there are more timing issues between different ICs that mean finding a 'set' that works well together is trial and error.
Progress at least though.
Return to “8 BIT CORNER”
