Thanks! These are very interesting pointers, I will check them out.thorsten.otto wrote: ↑Fri Feb 19, 2021 1:06 pmIf i understand that correctly, that works by firing up steem, passing some options. Maybe you can achieve similar things by using a similar tools (a Pure-C project parser) that i wrote some time ago (available at https://github.com/th-otto/pcmake).This way you won't have to start the Pure C editor, it works by simply double clicking the .PRJ file.
In newer VS versions, you can enhance the MSBuild environment. I've done that long time ago to add support for an old version of MASM. Similarly you should be able to define rules for a cross gcc compiler (either the cygwin version, or maybe simplier by using the plain mingw version which you find at http://tho-otto.de/crossmint.php). Maybe you can find some examples for this in other projects like NASM.I'm looking for a way to use cross compilation myself so I'm very interested in further suggestions.
Atari ST C Dev under Windows
Moderator: troed
Re: Atari ST C Dev under Windows
Coincidentally I just got Visual Studio Code for YAML stuff for work, so I will have a tinker since I expect it is a little simpler than full blown VS
It's an excellent editor, no exaggeration. I love it.rubber_jonnie wrote: ↑Fri Feb 19, 2021 2:00 pm Coincidentally I just got Visual Studio Code for YAML stuff for work, so I will have a tinker since I expect it is a little simpler than full blown VS
Yeah, I'm discovering that, but YAML still sucks!sandord wrote: ↑Fri Feb 19, 2021 2:17 pmIt's an excellent editor, no exaggeration. I love it.rubber_jonnie wrote: ↑Fri Feb 19, 2021 2:00 pm Coincidentally I just got Visual Studio Code for YAML stuff for work, so I will have a tinker since I expect it is a little simpler than full blown VS
