STe/ST video out port Q's
Posted: Thu Jun 23, 2022 2:54 pm
I'm going to be making myself something that plugs into the RGB port, providing a mono on-off switch & sound output. (To be used in conjunction with rgb2hdmi, so I can swap between colour/mono and have sound output)
Looking at the schematic, is it true that grounding pin 4 of the connector will enable mono mode?
Also for sound output, does the STe output stereo or mono from the monitor port? I can only see audio going to pin 1, but there is also something called AUDIOI on pin 5. Can I wire it up so that I can get mono out when plugged into an ST, and stereo when plugged into an STe?
