Xilinx programming cable USB -- anyone got this one?
frank.lukas
Re: Xilinx programming cable USB -- anyone got this one?
Post by frank.lukas »
Badwolf wrote: Wed May 25, 2022 9:28 pm What is your USB VID/PID pair now?
... the same as before!
frank.lukas wrote: Thu May 26, 2022 10:44 am
That's a shame. I was hoping if it had now been programmed by Impact it could be used with xc3prog. Never mind, if you have a working setup, we can at least try things. :-)
DSTB1 Open source 16Mhz 68k and AltRAM accelerator for the ST
frank.lukas
Someone over the Atari-home forum told me the driver is "xpc" but it not work correct with xc3sprog. Same can you read at the web.
Impact works fine ...
Hi Frank,
I believe your TT ram problem might only require re-flowing the solder on your ram chips and ram buffer chips.
I finished building a DFB1 today and it would not detect the ram even though I thought it was soldered perfectly. I put flux over and re-flowed and now it is all working.
Steve wrote: Mon May 30, 2022 3:45 pm Hi Frank,
Great to see another board firing on all cylinders, Steve!
I'm starting to wonder if @frank.lukas's problem is indeed a solder joint or similar that's vibrated loose in shipping as there does seem to be a time (which to me impies heat) dependence to it.
It's all very odd.
Hopefully we'll get there.
