@sporniket
That looks great. Im quite busy with easter stuff at the moment, but will look into it at some point soon.
Thank you
Twin Shifter mod Prototype build results
- mrbombermillzy
Re: Twin Shifter mod Prototype build results
No problem, it's also busy on my side.
- mrbombermillzy
Just to let you know, this is the first chance I have had to have a proper look at this.sporniket wrote: ↑Mon Apr 18, 2022 8:21 amHere it is. I hope it is clear enough.mrbombermillzy wrote: ↑Mon Apr 11, 2022 10:05 pm Could you maybe construct some sort of bitwise table/chart of which shifter positions are falsely repeated/missed by each shifter?
There seems to be 2 types of anomaly here.
For the first, which is where some of the bits set on both shifters cause errant unrelated bits to be set: I'm starting to look at RGB colour channel transformation to achieve minimal colour error. (This would be SO much simpler if there were not 5 consecutive bits with erroneous bits set!) Hopefully, once I've figured out the results, I can use the data to intercept bad bit combos and slightly tweak the colour so that (hopefully) it's unnoticeable to the naked eye. Anyway, more later, once I have some numbers to crunch/absorb and results to show.
As for anomaly 2, where one bit is set in only one shifter; I can't remember if you have something on the new board rev. that fixes this? (If not we will have to discuss/recap and I will have then a look at it too).
You can try that for the challenge of doing it, and I believe that you should not lose too much time on that, since it is a hardware bug that MUST be fixed. I plan to fix the schematic next month (now is school holidays), so I hope that a new version should be ready by July. Now that the manual interruptor is not needed anymore, I can repurpose the selector so that when the Shifter /CS is not asserted (Shifter not selected to read/modify internal register), the second shifter always receive the same data than the main shifter.mrbombermillzy wrote: ↑Mon Apr 25, 2022 8:39 pm For the first, which is where some of the bits set on both shifters cause errant unrelated bits to be set: I'm starting to look at RGB colour channel transformation to achieve minimal colour error. (This would be SO much simpler if there were not 5 consecutive bits with erroneous bits set!) Hopefully, once I've figured out the results, I can use the data to intercept bad bit combos and slightly tweak the colour so that (hopefully) it's unnoticeable to the naked eye.
I also believe that it is best to leave your current board untouched, as it is working enough to allow you to experiment with it.
(edit : fixed typos and missing words)
- mrbombermillzy
Ok then. With my time constraints, it's maybe better time spent for me to hang on if you are confident that you can get those issues fixed.
I have plenty of challenges elsewhere
Will return to coding the 16bpp/16 col image viewer.
