ubeswitch - video adapter.
Various other hardware solutions.
jacolover
Re: ubeswitch - video adapter.
Post by jacolover »
Hi, just received the MKVI from exxos, the little push button switch broke off, what kind of switch (part number) is it? I see its a 2-pole, is it a momentary contact or latching switch? Can I use the external switch pads to solder another switch onto it? Thanks!
ube
Post by ube »
Hm. It’s K2-1823SA. But that shouldn’t happen. Check your inbox. :)
master of the bare pcb
Gbrigden
Post by Gbrigden »
Hi,
Can you let me know when these will be available to purchase from your store please?
Thanks
Gbrigden wrote: Wed Oct 28, 2020 1:22 pm Can you let me know when these will be available to purchase from your store please?
You need to keep a eye on this topic https://www.exxosforum.co.uk/forum/viewt ... =90&t=2144
guigui668
Post by guigui668 »
Hello @all, I PM Ube for the same thing, my adapters provide to me lots of vertical band, i cleaned all, adjusted the trimpot for the best but still vertical bands.
Any advice (Monitor is a dell 1411U 15kHz compatible and a standard RGB cable of 50cm) ?
Thoe worst picture is on my Mste, the best on the 1040 STF, might thing about PSU/caps ?
Thxs a lot.
The adapters don't really do much in terms of video. Mostly its down to just old machines and problems with the scaling on the monitor etc. I know there's been several threads about this problem on the forum already if you have a look around.
ube
Post by ube »
I’ll drop it here as well. It’s a monitor clock thingy.
http://www.techmind.org/lcd/phasexplan.html
guigui668
Post by guigui668 »
exxos wrote: Sun Nov 21, 2021 6:30 pm The adapters don't really do much in terms of video. Mostly its down to just old machines and problems with the scaling on the monitor etc. I know there's been several threads about this problem on the forum already if you have a look around.
Yeah, i did read some of them.
The vertical lines are visible with clear colors, look like 'vertical' noise. I will make pictures sometime.
Thxs
Return to “HARDWARE ESSENTIALS”
