But that's what I'm saying. There is a 1280×720 resolution in the Raven BIOS as the last options.LarryL wrote: Wed Feb 04, 2026 9:21 ammy bigger (and more modern) monitor is 16:9 and all standard resolutions were 4:3Atarian Computing wrote: Wed Feb 04, 2026 7:00 am
In my limited usage, I haven't seen any artefacts. Why did you make a custom resolution when there was a built-in one?
In fact I had to fine tune all the resolutions to make them work with my 16:9 monitor
I also have a NEC 1990FXp which worked fine with the standard resolutions - need to check if there are artefacts, too
Please make sure you are logged in for at least 2 hours
to make sure your IP is added into the firewall whitelist, thanks
Atarian Computing's Raven Build
Atarian Computing
Re: Atarian Computing's Raven Build
Atarian Computing wrote: Wed Feb 04, 2026 1:12 pm But that's what I'm saying. There is a 1280×720 resolution in the Raven BIOS as the last options.
Will have a closer look… didn’t realise, maybe because most of the resolutions did not show any picture on my monitor
Thanks!
