Clock patch V2 and V4 installation questions:
The place to ask all those likely daft questions!
Swissfalcon
Post by Swissfalcon »
Hi,
I'm trying to understand exactly what are the exact steps to install the V2 and the V4 patch, mainly to decide which one I will choose (based of course of the difficulty and my skills), and I have one question:
On the V2 installation page, just after the 4th wire installation, there is this line:
Also a modification to the falcon needs to be done and shown HERE
but when I click this link, it show me the original clock page section. Is this a fault in the redirection, and it was mean to show the "V2 & V3 MANDATORY MODIFICATION" part, or is this another modification that is needed?
Just to summarise and to see if I understood everything correctly:
V2 installation:
1. solder the board over U63
2. remove R216, R221 & R222
3. solder the 4 wires to the pads
4. solder a 100K resistor on the bootleg track and connect the white wire to 0V on Ajax
nothing else?
V4 installation:
4. solder in the 100pF at the bottom for the FPU
5. do the SDMA mod (cut the bootleg trace, apply the 68R resistor and connect the 47Pf between the 68R and 0V Ajax)
I ask, because you say that the V4 is much more difficult to install, but to me, the seems to be the same difficulty (the part near the SDMA being the most difficult).
Thanks for your help!
Re: Clock patch V2 and V4 installation questions:
V4 final build only needs the cap on the FPU. IIRC.
Though my patches are more complicated than the generic Atari types and clones as mine fix more problems, so they are harder to install.
Swissfalcon
exxos wrote: Sun Jul 07, 2024 3:23 pm V4 final build only needs the cap on the FPU. IIRC.
oh! But the one actually on the shop isn't the final build, right? So, better for me to wait the final version? When will it be available?
And what about the link in the v2 installation manual that point to the Atari patch?
otherwise, is my summary correct for the installations steps?
Thanks
Swissfalcon wrote: Sun Jul 07, 2024 4:25 pm oh! But the one actually on the shop isn't the final build, right? So, better for me to wait the final version? When will it be available?
The one in the shop is the final build.
It's hard to check right now as I'm not at home on weekends to look properly at it all. But likely was a link I forgot to update to point to
https://exxosforum.co.uk/atari/last/fal ... .htm#V2MOD
It looks correct. But it's hard to remember every single upgrade and all the install steps. So it's better to look on the install pages on what's needed. But they are pretty similar I think anyway.
Swissfalcon
exxos wrote: Sun Jul 07, 2024 5:07 pm The one in the shop is the final build.
ok
ok, make sense, this is what I tought. Thanks
Ok. I think then I will go for the V4. There is one thing that still confuse me right now (sorry)
The installation steps on the dedicated web page for the V4 tell that the caps for the FPU and the SDMA mode are needed. But you just wrote before that the final version of the V4 clock patch don't need the SDMA mod:
So, what is the correct installation method? With or without SDMA mode?
Thanks for the clarification :-)
The correct install for the v4 is as shown on the website. You need to exactly follow what is written.
Swissfalcon
so, with SDMA mod then. I understand that the statement "V4 final build only needs the cap on the FPU" is an error, correct?
Swissfalcon wrote: Sun Jul 07, 2024 5:46 pm so, with SDMA mod then. I understand that the statement "V4 final build only needs the cap on the FPU" is an error, correct?
I was referring more to the level of difficulty between the V2 and V4. In terms of parts, be it resistors or caps on the SDMA, the level of difficulty makes no odds, it's the same. You still have to cut the bootleg track and fit parts. The only real difference is the V4 needs a cap on the bottom of the FPU.
Swissfalcon
oh, ok. Thanks
Return to “NOOB QUESTIONS”
