| • MultiMon | Multisynchro mode. |
| • SetMon | Sets the monitor type. |
| • SizeComp | Vgetsize compatibility. |
| • Vattrib | Alters attribute of a video mode. |
| • Vclose | Shutdown |
| • Vcreate | Adds a video mode. |
| • Vdelete | Deletes a video mode. |
| • Vfirst | Finds the first video mode. |
| • Vload | Loads VIDEO.DAT. |
| • Vlock | Locks the virtual screen. |
| • Vnext | Next video mode. |
| • Voffset | Gets position of the virtual screen. |
| • Vopen | Wakes up the screen. |
| • Vread | Obtains the current video mode. |
| • Vsave | Saves VIDEO.DAT. |
| • Vscroll | Chooses the method of scrolling. |
| • Vseek | Sets the position of the virtual screen. |
| • Vsize | Returns the size of the screen. |
| • Vvalid | Validates a video mode. |
| • Vwrite | Changes the screen resolution. |
Note:
These functions are only available under CENTScreen; they
are not routines of the operating system.
| Name: | »MultiMon« - Multisynchro mode | ||||||||
| Opcode: | 82 | ||||||||
| Syntax: | int16_t MultiMon( int16_t Cmd ); | ||||||||
| Description: | You can authorise the switch between RGB and VGA.
| Return value: | The old mode. | ||||||||
| Availability: | CENTScreen | ||||||||
| Group: | CENTScreen XBIOS extension | ||||||||
| See also: | Binding |
| C: | int16_t MultiMon( int16_t Cmd ); |
| Assembler: | move.w #Cmd,-(sp) ; Offset 2 move.w #82,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #4,sp ; Correct stack |
| Name: | »SetMon« - Set the monitor type. | ||||||||||
| Opcode: | 81 | ||||||||||
| Syntax: | int16_t SetMon( int16_t MontType ); | ||||||||||
| Description: | Set the monitor type.
| Return value: | The type of screen. | ||||||||||
| Availability: | CENTScreen | ||||||||||
| Group: | CENTScreen XBIOS extension | ||||||||||
| C: | #include int16_t SetMon( int16_t MontType ); |
| Assembler: | move.w #MontType,-(sp) ; Offset 2 move.w #81,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #4,sp ; Correct stack |
| Name: | »SizeComp« - Vgetsize compatibility | ||||||||||||
| Opcode: | 83 | ||||||||||||
| Syntax: | int16_t SizeComp( int16_t Cmd ); | ||||||||||||
| Description: | Vgetsize compatibility.
| Return value: | The old mode. | ||||||||||||
| Availability: | CENTScreen | ||||||||||||
| Group: | CENTScreen XBIOS extension | ||||||||||||
| C: | #include int16_t SizeComp( int16_t Cmd ); |
| Assembler: | move.w #Cmd,-(sp) ; Offset 2 move.w #83,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #4,sp ; Correct stack |
| Name: | »Vattrib« - Changes the attiributes of a video mode |
| Opcode: | 67 |
| Syntax: | void Vattrib( VDO_PARAM *InParam, VDO_PARAM *OutParam ); |
| Description: | This function allows you to change the parmeters of original
video modes. It is possible to change only the set, eco, eco2 and virt
flags, the virtual screen size and the screen saver waiting period. As the flag_set flag can be set only once for each resolution type, this function handles the previous mode deactivation. Of course, it is only useful for the former functions. |
| Return value: | The OutParam is filled with the prameters really set. |
| C: | #include void Vattrib( VDO_PARAM *InParam, VDO_PARAM *OutParam ); |
| Assembler: | move.l #OutParam,-(sp) ; Offset 6 move.l #InParam,-(sp) ; Offset 2 move.w #67,-(sp) ; Offset 0 trap #14 ; Call XBIOS lea 10(sp),sp ; Correct stack |
| Name: | »Vclose« - Shut down |
| Opcode: | 76 |
| Syntax: | int16_t Vclose( void ); |
| Description: | Shut down |
| Return value: | 0 : No error.
-1 : Improbable. |
| C: | #include int16_t Vclose( void ); |
| Assembler: | move.w #76,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #2,sp ; Correct stack |
| Name: | »Vcreate« - Add a video mode |
| Opcode: | 68 |
| Syntax: | void Vcreate( VDO_PARAM *InParam, VDO_PARAM *OutParam ); |
| Description: | It take directly the videl parameters and affect a new handle
on it with your parameters. It use by CENTvidel. |
| C: | #include void Vcreate( VDO_PARAM *InParam, VDO_PARAM *OutParam ); |
| Assembler: | move.l #OutParam,-(sp) ; Offset 6 move.l #InParam,-(sp) ; Offset 2 move.w #68,-(sp) ; Offset 0 trap #14 ; Call XBIOS lea 10(sp),sp ; Correct stack |
| Name: | »Vdelete« - Delete a video mode |
| Opcode: | 69 |
| Syntax: | int16_t Vdelete( int16_t Handle); |
| Description: | Doesn't move the handles but compresses the internal data. The handles may change after a save-load sequence. |
| Return value: | 0: No error
-1: Bad handle |
| C: | #include int16_t Vdelete( int16_t Handle); |
| Assembler: | move.w #Handle,-(sp) ; Offset 2 move.w #69,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #4,sp ; Correct stack |
| Name: | »Vfirst« - Search the first video mode |
| Opcode: | 70 |
| Syntax: | int16_t Vfirst( VDO_PARAM *Mask, VDO_PARAM *Mode ); |
| Description: | Finds the first video mode. |
| Return value: | 0: The out-array is full
-1: No mode match |
| C: | #include int16_t Vfirst( VDO_PARAM *Mask, VDO_PARAM *Mode ); |
| Assembler: | move.l #Mode,-(sp) ; Offset 6 move.l #Mask,-(sp) ; Offset 2 move.w #70,-(sp) ; Offset 0 trap #14 ; Call XBIOS lea 10(sp),sp ; Correct stack |
| Name: | »Vload« - Load VIDEO.DAT file |
| Opcode: | 73 |
| Syntax: | int16_t Vload( void ); |
| Description: | Load the VIDEO.DAT file. |
-1 : File not found. |
| C: | #include int16_t Vload( void ); |
| Assembler: | move.w #73,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #2,sp ; Correct stack |
| Name: | »Vlock« - Lock the virtual screen | ||||||
| Opcode: | 80 | ||||||
| Syntax: | int16_t Vlock( int16_t cmd ); | ||||||
| Description: | Locks the virtual screen.
| Return value: | The old configuration. | ||||||
| C: | #include int16_t Vlock( int16_t cmd ); |
| Assembler: | move.w #cmd,-(sp) ; Offset 2 move.w #80,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #4,sp ; Correct stack |
| Name: | »Vnext« - Next video mode |
| Opcode: | 71 |
| Syntax: | int16_t Vnext( VDO_PARAM *Mask, VDO_PARAM *Mode ); |
| Description: | Next video mode |
-1: No mode match |
| C: | #include int16_t Vnext( VDO_PARAM *Mask, VDO_PARAM *Mode ); |
| Assembler: | move.l #Mode,-(sp) ; Offset 6 move.l #Mask,-(sp) ; Offset 2 move.w #71,-(sp) ; Offset 0 trap #14 ; Call XBIOS lea 10(sp),sp ; Correct stack |
| Name: | »Voffset« - Position of the virtual screen |
| Opcode: | 78 |
| Syntax: | int16_t Voffset( void ); |
| Description: | Returns the position of the virtual screen in relation to the top left corner of the physical screen. |
| Return value: | Holds the current position with x in the high word and y in the low word. |
| C: | #include int16_t Voffset( void ); |
| Assembler: | move.w #78,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #2,sp ; Correct stack |
| Name: | »Vopen« - Wake up the screen |
| Opcode: | 75 |
| Syntax: | int16_t Vopen( void ); |
| Description: | Wake up the screen. |
-1 : Improbable. |
| C: | #include int16_t Vopen( void ); |
| Assembler: | move.w #75,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #2,sp ; Correct stack |
| Name: | »Vread« - Obtain the current video mode |
| Opcode: | 65 |
| Syntax: | void Vread( VDO_PARAM *Result ); |
| Description: | With one call you can know all the information about the installed video mode. |
| Return value: | Result is filled. |
| C: | #include void Vread( VDO_PARAM *Result ); |
| Assembler: | move.l #Result,-(sp) ; Offset 2 move.w #65,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #4,sp ; Correct stack |
| Name: | »Vsave« - Save a VIDEO.DAT file |
| Opcode: | 74 |
| Syntax: | int16_t Vsave( void ); |
| Description: | Save a VIDEO.DAT file. |
-1 : Save impossible. |
| C: | #include int16_t Vsave( void ); |
| Assembler: | move.w #74,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #2,sp ; Correct stack |
| Name: | »Vscroll« - Choose the method of scrolling | ||||||||
| Opcode: | 77 | ||||||||
| Syntax: | int16_t Vscroll( int16_t ScrollMode ); | ||||||||
| Description: | Choose the method of scrolling.
| Return value: | The old method. | ||||||||
| C: | #include int16_t Vscroll( int16_t ScrollMode ); |
| Assembler: | move.w #ScrollMode,-(sp) ; Offset 2 move.w #77,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #4,sp ; Correct stack |
| Name: | »Vseek« - Set the position of the virtual screen |
| Opcode: | 78 |
| Syntax: | VPOS Vseek( int16_t x, int16_t y ); |
| Description: | Sets the position of the virtual screen in relation to the top left corner of the physical screen. |
| C: | #include VPOS Vseek( int16_t x, int16_t y ); |
| Name: | »Vsize« - Return the size of the screen |
| Opcode: | 84 |
| Syntax: | Bindings for Vsize |
| Description: | This function allows you to know the size of a screen with
input parameters. If you put -1 for handle, the current handle is taken by default as a reference. The function reads only the logical parameter (not if -1) and the virtual flag (not if -1). Parameters: Long: in-array |
| Return value: | D0 hold the size in bytes.
0 for error (bad parameters ?!) |
| C: | ????? |
| Assembler: | move.l #Mode,-(sp) ; Offset 2 move.w #84,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #6,sp ; Correct stack |
| Name: | »Vvalid« - Validate a video mode |
| Opcode: | 72 |
| Syntax: | int16_t Vvalid( int16_t Handle ); |
| Description: | Validate a video mode. |
| Return value: | 0: If the mode exists
-1: No mode for this handle |
| C: | #include int16_t Vvalid( int16_t Handle ); |
| Assembler: | move.w #Handle,-(sp) ; Offset 2 move.w #72,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #4,sp ; Correct stack |
| Name: | »Vwrite« - Change the screen resolution. |
| Opcode: | 66 |
| Syntax: | int16_t Vwrite( int16_t InitVDI, VDO_PARAM *InParam, VDO_PARAM *OutParam ); |
| Description: | It is possible to use the VDI in order to use the graph
functions immediately. It allows to reallocate the needed screen for
the chosen video mode. With InParam, you can send the new desired resolution:
Once the resolution is passed in argument to the function, the output array contains the mode actually passed (useful to validate the mode). In case of failure (not enough memory for the VDI screen, invalid handle, or requested resolution too small), the current mode is returned for information in the output array, in addition an error message is provided. |
| Return value: | After the call, OutParam contains the real resolution
made. If an error occurs, the actual resolution is returned with -1. |
| See Also: | Binding |
| C: | int16_t Vwrite( int16_t InitVDI, VDO_PARAM *InParam, VDO_PARAM *OutParam ); |
| Assembler: | move.l #OutParam,-(sp) ; Offset 6 move.l #InParam,-(sp) ; Offset 2 move.w #66,-(sp) ; Offset 0 trap #14 ; Call XBIOS lea 10(sp),sp ; Correct stack |
