| • Bioskeys | Resets Bios table for key-codes. |
| • Kbrate | Gets or alters auto-repeat of the keyboard. |
| • Keytbl | Assigns new mapping table for key-codes. |
See also: ASCII table Scancode table
| Name: | »Bios standard keys« - Reinitialize keyboard. |
| Opcode: | 24 |
| Syntax: | void Bioskeys( void ); |
| Description: | Bioskeys is an XBIOS routine for reinitialising the key-codes. Usually this is only required if the keyboard has been reprogrammed with the Keytbl function. |
| Return value: | The function does not return a result. |
| Availability: | All TOS versions. |
| Group: | Keyboard functions |
| See also: | Binding Keytbl |
| C: | #include void Bioskeys( void ); |
| Assembler: | move.w #24,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #2,sp ; Correct stack |
| Name: | »keyboard rate« - Set the auto-repeat rate of the keyboard. | ||||||
| Opcode: | 35 | ||||||
| Syntax: | int16_t Kbrate( int16_t initial, int16_t repeat ); | ||||||
| Description: | The XBIOS routine Kbrate obtains or alters the current
auto-repeat rate of the keyboard. The following apply:
| Return value: | The function returns the setting of the auto-repeat mode as a
word, in the following way:
| Availability: | All TOS versions. | ||||||
| Group: | Keyboard functions | ||||||
| See also: | Binding |
| C: | #include int16_t Kbrate( int16_t initial, int16_t repeat ); |
| Assembler: | move.w repeat,-(sp) ; Offset 4 move.w initial,-(sp) ; Offset 2 move.w #35,-(sp) ; Offset 0 trap #14 ; Call XBIOS addq.l #6,sp ; Correct stack |
| Name: | »key table« - Define the mapping table for the keyboard scancodes to key-codes. | ||||||||||
| Opcode: | 16 | ||||||||||
| Syntax: | KEYTAB *Keytbl( void *unshift, void *shift, void *capslock ); | ||||||||||
| Description: | Keytbl is an XBIOS function with whose aid a new keyboard
table for the mapping of scancodes to key-codes can be constructed.
Note: A code is converted by using the scancode of the relevant key as an index in an array forming a table (of ASCII characters). Each of the tables has space for 128 entries, although key combinations with higher scancodes exist. | ||||||||||
| Return value: | The function returns a pointer to the KEYTAB structure. | ||||||||||
| Availability: | All TOS versions. | ||||||||||
| Group: | Keyboard functions | ||||||||||
| See also: | Binding Bioskeys ASCII table Scancodes |
| C: | #include KEYTAB *Keytbl( void *unshift, void *shift, void *capslock ); |
| Assembler: | pea capslock ; Offset 10 pea shift ; Offset 6 pea unshift ; Offset 2 move.w #16,-(sp) ; Offset 0 trap #14 ; Call XBIOS lea $E(sp),sp ; Correct stack |
