Midex+ driver question
somaboy
Post by somaboy »
Has anybody had any luck getting the Midex+ to work with the MCA cracked Cubase 2 on a mega STE?
It works with my official version of Cubase, but the MCA version doesn't seem to find it. I tried several drivers (midex115.drv, midex105.drv, midex.drv) but whatever I try, I cannot select Midex in the output column.
If anyone has a working configuration, would you mind sharing the disk image?
Cheers
Soma
mal7921
Post by mal7921 »
Look in the folder called MROS, in there are the drivers for lots of kit. Find the midex driver and change the extension after the . to DRV, then start cubase.
If it isn't there, I put the latest MROS version plus drivers on the Cubase Audio disk, download that and copy the driver from there.
Hope that helps.
The collection:
Atari 260ST, 520ST, 520ST+, 520STfm, STacy, Mega ST2
Atari STe, Mega STE, ST Book
Atari TT030, with 2GB Hard drive
Atari Falcon, 14MB, 40GB IDE drive
Atari Megafile 44
The website and the Atari bit
somaboy
Re: Midex+ driver question
Post by somaboy »
Thanks,
After trying numerous combinations of cubase disk images, midex drivers and mros versions I found a configuration that works smoothly.
Soma
charles
Post by charles »
soma you didn't want to work some songs together, this way you can learn as u go .. i have years experience and desire someone to collabarate with,,what music style are you hoping to follow?
charlie
Return to “Atari Audio & MIDI Peripherals”
Users browsing this forum: No registered users and 1 guest
