Sound suddenly has died
yerzmyey
Post by yerzmyey »
Hi guyz,
1) the sound in my Falcon has suddenly died.
There is _some_ sound but it's veeeeeeeeeeeeery silent.
Almost nothing.
I've been told it's a matter of dead capacitors. On the track of sound.
Is that true that it's enough to change them and everything will be OK?
2) Are they accessible nowadays?
3) Ah, one more thing. There are also 2 amplifiers on the track of sound (two - for both stereo channels). Are they possible to buy contemporary too?
As You know, except of MIDI stuff, I also use often Falcon 030 as an instrument, so it's very important to me.
Greetz,
Y
_______________________________________________
ZX, Atari, Amiga music: http://yerzmyey.i-demo.pl/
ATARI 520ST digital music: http://ym-digital.i-demo.pl/
mal7921
Re: Sound suddenly has died
Post by mal7921 »
The amps are pretty standard chips and as far as I'm aware are still available. The same thing has happened to my Falcon but with everything that has happened recently (And a wedding in 10 days...Gulp), fixing it has been on the back burner.
Simbo on the Atari Forum would be the best bet for finding out what the parts are and the most likely suspects for failure on the hardware, though there is another possibility...
If the wrong line has been inserted into the jack, it can send the amplification section a bit haywire, there is an accessory that can reset this and may fix the problem before taking things to bits. Unfortunately I can't find it here, so I'll get it off my Falcon and upload it.
In the meantime ResetNVR may also help and can be found at http://www.atarimusic.net/warez/system- ... d-bootc123.
The collection:
Atari 260ST, 520ST, 520ST+, 520STfm, STacy, Mega ST2
Atari STe, Mega STE, ST Book
Atari TT030, with 2GB Hard drive
Atari Falcon, 14MB, 40GB IDE drive
Atari Megafile 44
The website and the Atari bit
mal7921
Post by mal7921 »
Ok, fired up the falcon and pulled the accessory. The link is http://www.atarimusic.net/Atari-Music-N ... lconSX.zip.
Hope this helps
The collection:
Atari Megafile 44
yerzmyey
Post by yerzmyey »
Thanks a lot, I do appreciate the help. I saved it and will use it soon.
Meanwhile I also consider to test an opportunity that if the analogue output is dead, then maybe the digital one could still work. Who knows.
I ordered some pieces of hardware and will make further tests.
Greetzzzzzz,
Y
mal7921
Post by mal7921 »
If you can hear faint sound then the audio section itself is ok and working. Which means a digital out should still work fine :-)
The collection:
Atari Megafile 44
mal7921
Post by mal7921 »
Hmm... Just a thought but have you checked that the cable is ok? While the is still a chance of a hardware fault, it is also possible that the cable is faulty.
Having said that though, if you can use the FDI digital out, that will always give a better sound quality than the falcons analogue audio output
The collection:
Atari Megafile 44
yerzmyey
Post by yerzmyey »
Yupp - that's what I intend to check out. ;)
The stuff should come to me by post this week, I hope.
We will... hear! ;)
Return to “Atari Falcon 030”
Users browsing this forum: No registered users and 0 guests
