Soundpool Falcon Analog 8/4 Interface REV A
NCGM
Post by NCGM »
I have one of these and today I thought I would open it up to have a nosey. I discovered that it is a revision A model, so does this mean I may have problems? I suppose I should just have a quick session with Cubase Audio to find out! I also still have the Steinberg FA8 and this seems to work fine for me, but I got the Soundpool to match the green SPDIF interface :mrgreen:
I suppose I could go for a compromise and stick the Steinberg motherboard inside the Soundpool case, but I might want to sell one and keep the other.
So is revision A worth keeping?
mal7921
Re: Soundpool Falcon Analog 8/4 Interface REV A
Post by mal7921 »
As far as I know the Soundpool branded devices always used the higher grade components so you should be ok.
I've had both devices and could interchange them just fine, the only issue I had at the time was I didn't have enough power supplies to run them on more than one falcon...
Not an issue these days though.
The collection:
Atari 260ST, 520ST, 520ST+, 520STfm, STacy, Mega ST2
Atari STe, Mega STE, ST Book
Atari TT030, with 2GB Hard drive
Atari Falcon, 14MB, 40GB IDE drive
Atari Megafile 44
The website and the Atari bit
NCGM
Post by NCGM »
Here are some photos of my Soundpool Falcon Analog 8/4 and Steinberg Falcon Analog 8 interfaces, so you can compare the circuit board components and layout. The first two photos below are the SoundPool, then the next two are the Steinberg.
Click on them and select 1600x1200 for the largest size.
Return to “Atari Audio & MIDI Peripherals”
Users browsing this forum: No registered users and 0 guests
