maxyMiser sync as slave
xfalcon
Post by xfalcon »
I'm trying to sync maxyMiser as slave with cubase, for example. But it didn't work.
MaxyMiser seams to play everything much faster.
Cubase send midi timeclock and midi clock. at 30 bmp.
MaxyMiser start playing at maybe 300 bpm.
In maxyMiser Midi Ctrlrs is enabled and in the normal panel I switch interruption to midi. Have I forgot something?
thank for help
chris
https://soundcloud.com/xfalcon-dma - Songs - Sounds - Beats
Falcon 030 14 MB +Dayna Port::MegaSt4 +Hydra, Overscan & UltraSatanDisk
mal7921
Re: maxyMiser sync as slave
Post by mal7921 »
I've not had chance to download or try maxYMiser so I can't really guess at what could be causing this, unless it's something simple like SMPTE sync or something like that.
The author can be contacted here and as atarisince1989 found out, he is generally quick in responding.
The collection:
Atari 260ST, 520ST, 520ST+, 520STfm, STacy, Mega ST2
Atari STe, Mega STE, ST Book
Atari TT030, with 2GB Hard drive
Atari Falcon, 14MB, 40GB IDE drive
Atari Megafile 44
The website and the Atari bit
atarisince1989
Post by atarisince1989 »
Yeah, contact gwEm and share with us whatever information you get. That idea of yours about sync maxYMiser with Cubase, seems like a very interesting thing to have.
My toys:
- Atari 520 STE 4MB RAM TOS 2.06 + UltraSatan
- Atari Falcon030 (running SpareMiNT+TeraDesk) 14MB RAM TOS 4.04 + 4GB Microdrive & external CF slot + NVRAM mod + SCSI buffer clock mod + EtherNEC
- Amstrad CPC 6128 + HxC USB Floppy Emulator
xfalcon
Post by xfalcon »
MaxYMiser don't support SMPTE, just MIDI clock.
I had a problem with my midi patchy. It's midi timepiece (MTP AV) from make of the unicorn. That's the reason way the synchronization failed with midi clock.
Now I connect the MegaSt direct to the falcon and now it work fine.
Does anyone have an idea what's wrong with the midi timepiece?
thanks
chris
mal7921
Post by mal7921 »
Ooh, very odd. Mind you some early MIDI patchbays which could be controlled by MIDI data had trouble with sysex dumps and timing critical data, sysex because of the sheer volume of data and timing stuff because it could upset the data sequence and introduce delays.
I assume it was all working ok if you just played a keyboard and recorded the output (Or sent it to a sound module)?
The collection:
Atari Megafile 44
atarisince1989
So, correct me if I'm wrong, the idea is that you connect through MIDI 2 Ataris (one running maxYMiser and another running Cubase) and then from Cubase you can kick the maxYMiser to play/stop patterns, so at the end you could mix the audio of the two Ataris and have mixed composition?
My toys:
mal7921
Post by mal7921 »
atarisince1989 wrote:So, correct me if I'm wrong, the idea is that you connect through MIDI 2 Ataris (one running maxYMiser and another running Cubase) and then from Cubase you can kick the maxYMiser to play/stop patterns, so at the end you could mix the audio of the two Ataris and have mixed composition?
In theory you could sync 2 computers, 1 running a MIDI program controllong synths, samplers and stuff like that and a second running another program which could be a sound source or another MIDI program controllong another bank of synthesizers. The MIDI Time Control should lock the 2 computers to the same tempo and position in their relative song files so that everything on the 2 computers plays at the correct time, even though they are running different programs controlling different things.
In practice it usually works really well, but if I were doing it I'd have 2 Atari's connected with the built in MIDI for sync and use an external interface for any external MIDI gear.
The collection:
Atari Megafile 44
atarisince1989
mal7921 wrote:In practice it usually works really well, but if I were doing it I'd have 2 Atari's connected with the built in MIDI for sync and use an external interface for any external MIDI gear.
Malcom, sorry I don't quite get it. I'm thick sometimes :roll: . What kind of external interface? Then the MIDI Ataris and the MIDI gear will be independent and not connected between them?
My toys:
xfalcon
Post by xfalcon »
mal7921 wrote:Ooh, very odd. Mind you some early MIDI patchbays which could be controlled by MIDI data had trouble with sysex dumps and timing critical data, sysex because of the sheer volume of data and timing stuff because it could upset the data sequence and introduce delays.
I don't know exactly, but the MTV AV is not the cheapest midirouter.
In the mean time I checked out some other synchronizations.
Cubase to cubase,
Mandala to cubase,
pulsar to cubase.
It all works fine with the midirouter. Only with maxYMiser I have problems. :?
Have maxYMiser a midi thru funktion?
atarisince1989 wrote:, correct me if I'm wrong, the idea is that you connect through MIDI 2 Ataris (one running maxYMiser and another running Cubase) and then from Cubase you can kick the maxYMiser to play/stop patterns, so at the end you could mix the audio of the two Ataris and have mixed composition?
Yes, that's right.
Return to “Atari”
Users browsing this forum: No registered users and 0 guests
