Hello,
I would like to use cubase on Steem and to have the possibiliy to choose as midi output the sounds that the vhost utility programm give me (any plug in vst that I load)
steem midi and vhost utility on pc
Re: steem midi and vhost utility on pc
Hmm... As I remember Steem needs a physical MIDI interface , though you may be able to use a MDI routing utility such as MIDIYoke but someone else will have to confirm that as I don't have a Windows machine in the house any more.
If you have an external MIDI interface on your PC with more than 1 set of MIDI ports, you can use this as a router by setting Steem t use MIDI in/out 1 and your audio application to use MIDI in.out 2. Put a MIDI cable between MIDI out 1 and MIDI in 2 and load Cubase on Steem and your audio app in Windows, the set your audio app to use MIDI in/out 2 and then Cubase will have control over your Windows synth.
This of course means having an external MIDI interface on your PC, and if the MIDIYoke idea does not work would most likely be your only option.
The collection:
Atari 260ST, 520ST, 520ST+, 520STfm, STacy, Mega ST2
Atari STe, Mega STE, ST Book
Atari TT030, with 2GB Hard drive
Atari Falcon, 14MB, 40GB IDE drive
Atari Megafile 44
The website and the Atari bit
Atari Megafile 44
Users browsing this forum: No registered users and 0 guests
