cubase 3 "delay" problem
I use an akai s1000, sometimes I can't be bothered to edit a sample/loop/break on the akai to get it in time, I sometimes use the "delay" tool when you've selected apart, I'll click for about -20 for example, but when I do this, some sounds cut off, I found out I could solve it by shortening length notes in that part but it's a bit time consuming, why does this happen? I have a legit cubase 3 and I'm running it on a 1040ste with 4mb
Re: cubase 3 "delay" problem
Is it in the beginning or end of a part? With the delay Cubase can miss a note because it starts before the part now.
Kind regardz,
Joz
http://www.waxnwane.nl
1 Falcon 030, FPU, 14 MB RAM, 2 Gb SD card
2 x Mega STe, TOS 2.06, 4 Mb RAM, 30 Mb harddisk
1 STe, TOS 2.06 (replaces older TOS), 4 Mb RAM
Joz
One thing to remember is that when you delay a note to make it play on time, if your wanting to play it again in the next part it can cut the original sound off as it starts playing again 20ms before the original note has finished. If your running out of voices i=on the sampler, or your just trying to create a looping effect (Or both on occasion) then this will happen.cheeky_robin wrote:I use an akai s1000, sometimes I can't be bothered to edit a sample/loop/break on the akai to get it in time, I sometimes use the "delay" tool when you've selected apart, I'll click for about -20 for example, but when I do this, some sounds cut off, I found out I could solve it by shortening length notes in that part but it's a bit time consuming, why does this happen? I have a legit cubase 3 and I'm running it on a 1040ste with 4mb
While it can be a pain, I'd at least edit the sound so that there is no silence at the beginning as any silence at the end would be cut off when the note finishes or the next note starts.
Avalon and Zero-X (Both available here) will do this on your Atari if you find the Akai too fiddly to edit with direct.
The collection:
Atari 260ST, 520ST, 520ST+, 520STfm, STacy, Mega ST2
Atari STe, Mega STE, ST Book
Atari TT030, with 2GB Hard drive
Atari Falcon, 14MB, 40GB IDE drive
Atari Megafile 44
The website and the Atari bit
Atari Megafile 44
sorry for the late reply!
thanks alot will check that out!
Users browsing this forum: Google [Bot] and 0 guests
